tanman_2006
Just a farm kid...
You could use everything off a 93, waste gate spring and GP relay.
Will all of my gauges still work?
Do I need new injector lines? Or I guess I should ask what do I need?
What DB 2 pump will I need?
Short list for a standard trans conversion.
IP
IP lines
Water temp sensor in xover (cant remember name) for cold advance.
Throttle cable
Throttle pedal from gas truck
Am I missing anything?
With an auto you would need many more parts.
If it was an automatic then I would leave it alone.
Do I need a throttle cable and pedal from gas truck or just the pedal? 89-95 TBI parts I assume?
I found a new 4879 pump for a reasonable price.
Pedal from any 88 2000 gas truck.
Cable from a diesel.
You will also need the throttle bracket on the IP
I thought 96-00 trucks were fly by wire too? Not doubting you, I'm just curious.
Cable from a 92-93 6.5 TD only, or can I get one from any 6.2/6.5 88-93?
Also the truck doesn't have factory Cruise, is there any difference in the throttle cable/ bracket for a truck with Cruise? I will be adding Cruise later.
Thanks for all of the help guys! I hope to get this rolling soon, parts collecting will begin this week.
As far as I know all the gassers had a peddle with a cable.
Don't know why a cable from a 6.2 would'int work.
Throttle backet is same with or w/o cruise, but to add cruise you will need the addition bracket that bolt to the throttle bracket.
just read this thread,
first off, congrats on resurrecting it! your truck follows that addage "real pickup trucks have three pedals, two sticks, and no spark plugs!"
Im sure from OK, she is fairly rust free, correct?
also, as far as pedals, from my boss' 88 BBC RCLB, to dad's 00 350/auto chassis cab, they all have throttle cables. throttle cables on GM gas trucks seemed to go till 03 (IIRC, 03 was the last year of a few traditional things, throttle cable being one, out-of tank, changeable fuel filters another)
lastly, I agree with dropping the oil, my boss always does it on dead tractors he buys, but he got lazy on a 5020, and she locked up idling in the yard. slimy filter, thick, black oil.
also, do you plan on rebuilding the truck completely yourself? (further embrace that sentimentiality, making yourself the one and only physician on the ol girls recovery!)
if you are intimidated about the 5spd, one source i recommend is www.quad4x4.com they have their own rebuild manual with pics, etc, and they carry many parts, and tools to get the job done.
good luck!
did I miss something how did you determine it was pcm?
I wouldn't condem the pcm just yet. With dead batteries ,even a jump may not be enough to get 12+ volts to the ecm. Did you check ALL the fuses with a ohm meter? Have you checked voltage going into the ecm from all supply circuits? If the engine ran when it was parked, chances`are that it is a connection problem. ECMs don't die from lack of use.The ignition switch is always suspect in a 95+. How old are the battery cables?[don't have to look bad to be bad]There is no CEL or Glow Plug light at start up. I checked and there is not power to the glow plugs and no fuel to the injectors.
I forgot to check the lift pump while I had the jumper cables hooked up.:mad2:
If you have any more ideas on what to check feel free to let me know.
pcm is behind the jockey box
