doober
Hey Guys, My wife was driving our 95 6.5 suburban home from work this evening and said the truck started running rough all of a sudden at high way speeds. The oil pressure was normal and the water temp was normal so I told her to come on home.
She got home and I pulled the codes via. the paper clip method and this is what I found for codes,
Code 18 (Pump Cam Reference Pulse Error)
Code 19 (Crankshaft Position Reference Error)
Code 35 (Injection Pulse Width Error, (Response Time Short)
Code 54 (PCM Fuel Circuit Error)
I started the suburban in the drive way and it ram real rough and died in park when I tried to give it some fuel. I then started it back up right away and it ran okay and the service engine light went out. I shut it back off and started it right back up and it ran rough again and the service engine light came back on and I gave it alittle throttle and it even sounded like it was back firing just alittle bit and I shut it right off.
Anyone have any Ideas on what might be wrong? Really appreciate any and all the help you guys might have for me. Thanks.,
