porkchop12
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _Truck sat for about a month. Truck will crank but won't fire. Added more fuel under the fuel filter. It's gets sucked up in the engine but won't fire._______________
- Year: __2000____
- Truck model and class (ie: c2500) c3500 dually_
- Automatic or Standard __auto________
- Mileage: (indicate miles or km) 133,xxx_________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) unknown just got truck___
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? F engine______
- Ambient outside temp: (indicate *C or *F) _____60 degrees *F_____
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _Idk what's in the tank___
- What fuel additives are you using? _______none____
- Where are you located? _chesterfield, Va___________
- Air filter ____unknown_____
- Fuel filter ____haven't changed yet_____
- CDR Valve? _____unknown____
- Coolant – last flushed/replaced at __haven't changed since I have owned truck_
- Oil – synthetic/regular, changed at ____haven't changed yet, any recommendations_______
- Batteries – state of charge, (matched set) replaced at ____matched set new as of April 2016_________
- Battery cables and grounds (removed, cleaned and tightened): ___yes___________
- Glow Plugs - how many miles on them? _unknown____ What type? Unknown. Was told by last owner I need to change them.
- Injectors - last changed at ________unknown_______
- What were you doing when it happened? ___Truck sat for a month___________
- How was the truck running fine before this problem appeared? ____ previous owner said it would stall occasionally. I bought the truck without hearing it run. _________
- Has this problem ever happened before? _________unknown______________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __n__ And? ______engine light is on. Will check later this week.__
[FONT="]
[/FONT] Diagnostics:
1] Starting:
1a] Does the engine start? ___no____
1b] Does the engine crank over? ______yes__
1c] Are your batteries fully charged? ______yes___
1d] Have you removed, cleaned, and tightened all battery connections? ___only battery connections and the grounds I have found._____
1e] Does your Wait to Start light come on for a time? How long? _let in cycle fully before trying to start it. I don't know how much time._____
1f] Does your glow plug light come on? ___unknown______ For how long? _unknown___
1g] Do you see smoke from the exhaust while cranking? What color? ___never checked_____
1h] Does the Service Engine Light Glow during Start/bulb check? Dims as cranking I believe
2a] Can you hear your lift pump working? _didn't listen for it
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____no_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? Haven't checked.
2d] Loosen an injector line and crank the engine - does fuel come out? Haven't checked
2e] Do you hear a vacuum (hiss) when you remove the fuel cap?no
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _____ Ken location______
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ____no_____
3d] PMD Make: ___unknown.________
3e] PMD Age: _____unknown________
4] Stalling Issues
4a] Do you experience stalling only when hot? ______unknown.______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ____unknown__
4c] Does pouring cool water over the IP seem to help with restarting? _____unknown____
4d] Is stalling momentary (engine recovers)? _____unknown____
4e] Does SES light come on when engine hiccups? ____unknown_____
4f] Does cruise control quit working when engine hiccups? _______unknown____
4g] Does re-starting seem to reset engine, restoring cruise and power? _______unknown__
4h] Changes to dash lights or instruments during stalling events? _______ unknown____
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ____unknown___
5b] Any bubbles or oil film in coolant overflow tank? _____unknown__
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____unknown_____
5d] Excessive white smoke from exhaust on cold start? _______unknown__
5e] Excessive black smoke from exhaust under hard acceleration? Unknown
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ______no_____
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ___________unknown___
6d] Have you changed exhaust / downpipe / crossover? ___________no_____
6e] Wastegate – mechanical or vacuum (OEM)? ___________oem___
7a] Single or dual thermostats? ________unknown____
7b] Have you replaced them lately? Manufacturer of replacements? ______no___
7c] Have you pulled and cleaned Radiator and coolers lately? ______no______
7d] Have you replaced the fan clutch? Manufacturer of replacement? ______no__
7e] (winter) Have you tested your antifreeze? Good to what temp? _____no_____
7f] (winter) Are you using a winter grille cover? ___________
Bought this truck from Maryland in September of 2015 had towed home. My mechanic had it running the next day. I started once a week until I had surgery in January 2016. Truck sat until March. I only cranked it twice in March. Been not starting since the 3 rd week in March and is ticking me off. Please help
Corey
- Year: __2000____
[FONT="]
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
Corey
