BigBearZach
Found the problem it was a bad starter. Thanks for all the help
hereSome time back, around two years maybe, I started a thread called "Here's why you check your battery cables". Thinking this would be a good thread for BigBearZach, as think I had pics in it also, I tried to find it, but couldn't.
For those who are better at computers than I am can somebody find it? I tried advanced search, but couldn't find it.
Anyway, the upshot is that the battery cables can be badly corroded inside the insulating covering and it is not easy to see. The stock cables have a red rubber cover completely surrounding the brass mounting plate. This rubber covering can create problems with getting good contact between the battery post and the cable. Completely remove the outer end portion of this covering and wirebrush the contact surface of the cable end so you can insure the battery cable is making good contact with the battery.
Don
