- Staff
- #41
Or go with the nicktane OEM replacement filter head and use CAT spin-ons.
*Knock On Wood* Still on the originals on the 05, but it also has half the miles of Mike's truck.
IDK why people complain about changing the fuel filter on these. I don't have to remove anything to get at it. Although being 6'6" might have something to do with it...
You fellas should try a LML... It's even worse.. I changed mine for the first time last week and said a few choice words. Going in from the top on this truck isn't going to happen from what I can see. I'm not short either..
Either of you want to come and tackle changing mine out? I'm willing to bet the LML has alot more room than I have, and the new trucks are a walk in the park to do compared to mine. I pulled the battery last time to get to mine as I just couldn't get it loose otherwise. And putting the new one in is a pure PAIN IN THE A$$!
Your custom job doesn't count!
Ferm: That is what happens when you try and put 10 lbs into a 5 lb box! :rof: Just kidding. I'll bet yours is tough, seeing you did the engine swap. A little tradeoff, for a better running and more powerful motor. Just a little harder for the maintenance.
No start this AM. Just clicking like a dead battery. Keeps resetting oil life monitor to 0%. Disconnected both batteries and am reading a bit over 12V on each. No codes.
Went through car wash yesterday and it was running fine. Been in the shop at around 40* minimum overnight. I noticed it was cranking a bit slow lately.
Ideas?
I bet Bruce (racedaymechanic) would make a better kit for your trucks, if somebody were to take a Duramax to him so he could get measurements!
Good point. I'd guess the new generation of LB7 injectors are pretty much bulletproof though.and move the FICM where the second alternator is supposed to go...I want a clear shot at them valve covers in case I need to do injectors sometime in the future...
Nope. Still suck...
