3500GMC
What T F, over
Messy. My condolences.
Maybe some thrust bearing material in the pan... As a garnish.
Guys, this is why we keep the IP's and injectors HAPPY. A better dampener can't hurt either. If each cylinder is not firing 90 degrees apart, bad things happen. The cast crank just can't handle the tortional abuse. We know IP's and injectors get SLOPPY after being tortured several hundred thousand miles...
