Matt Bachand
Depends on the 6.5
Glad to hear Ghost... Exciting times for your 6.5 ... Need some pix in your album!
heres an update for you guys.. its running again.. and wow, what a differance in output pressure and flow.. i immidiatly saw the differance when i bled the system.. it shotout the fuel from the filter purge valve and showered the hood!!! first time!!! and the T valve output is also impressive..
truck is back to starting instantly again, but its 45* today.. so maybe thats a big help..
but anyway..
that horrible twin diesel noise i had before the truck died........
busted flexplate, and yes, its a definate!! i guess my original inspection when the trans seperated wasnt as good and thorough as i thought.. hairline crack maybe? anyway, took the inspection cover off at a rest stop, and can visible see the flexplate wobbling in sync with the noise.. as if the wobbling wasnt enough.. lol.. so its going under the knife, AGAIN!! on wednesday..
at the same time, valve adjustment, hopefully ill throw in the flowmaster Xover and DP, time will tell that day..
