ghost183
im really not trying to crank up my post count.. i swear ):h i swear lol..
i need verification from the pros.. yah.. thats you guys.. you know who you are ):h :cheers2:
but i need to know which is likely the culprit, theres irony to this story.. but ill tell you later
driving down 95 south today, and while doing so, i noticed erratic behavior from the engine, let me explain..
southbound, empty, just going to give a proposal for a job.. no rush, cruising along at 70, truck was running ok, i wouldnt say at its best.. but ok, its getting the job done considering whats been going on these past few weeks,
as im driving, my engine starts making a horrible noise, almost as if 2 diesel engines were under there, but very load specific, not rpm specific.. let me explain.. the first thing that came to mind when this started was gather as much info to post ):h
so...
the noise starts, i instantly look at my gauges (for any dead needles) and chop the throttle,
using memory they were all as normal
rpm=2200 +/-
temp=170 +/-
voltage = 14
oil = 40-45 psi
mph = 70 +/-
but noise goes away when i chopped , i say to myself (been happening alot lately) let me get off the turnpike before i start diagnosing and taking notes...
so to make this short, when the engine is "just shy of maintaining" i would say, like on a veeeery slight down hill it would make that noise, not on uphills, or engine braking, not under acceleration, not at idle.. just when spinning along with mph, like speeding up to 65 and letting off the throttle a little to match rpm with speed..then letting off 100-200 rpm more, not pulling, or engine braking.. just shy of maintaining, so i figure, trans seperated from engine again,, so i get off exit 7, look under at trans, still bolted tight, no fluids leaking, engine still idling, noisier than an hour ago (at this point) injectors are making a noticeably louder clicking, but idling smoothly.. no shacking.. so i look at trans fluid=full, coolant=good, belt=there and spinning, steering pump=full, everything seems ok so far, so i start the fuel test...
grab my pliers, crack the T valve, slide the pliers into my back pocket, spin it by hand, slowly at first, nothing is coming out, i continue opening it slowly, till im all the way, and soon as it taps out at max open, 15-17 secs after i start spinning, truck surges up 200-300 rpm and dies.. and it hasnt started since
LP is silent, turn key on=silent, crankin=silent, while cranking, i was looking at the oil pressure and it actually climbed, not much, but i couldy see the needle moving up and down in unison with rpm variations during cranking..
is the gauge sender and the OPS one in the same? im assuming its a seperate unit but anyway, also, i jumped the LP using the jumper under the hood.. nothing.. tapped it with the pliers hoping to wake it up, nothing..
ok, heres where i need your advice fellas....
1) lets say the OPS is bad, if i jump the LP directly, it should run? right?
2) but if i do jump it, and nothing, its the LP.. right?
3) also, im assuming by cracking open the T i let air in there, shouldnt a "healthy" IP pull the fuel back up, even if air is present???
4) and if it doesnt, IP is going?
keep in mind my PMD isnt 100%, a new one is coming, but the thought of the PMD buying it?, that would be a 1 in a million coincidence, it dies the instance i crack open the T valve??!?!?! what are the chances of that???????
and oh.. NO codes during all this
irony is, i dont remember hearing the LP for last few days, the other problems have taken my concentration.. but it was always noticeable.. i dunno..
so...
rpm=2200 +/-
temp=170 +/-
voltage = 14
oil = 40-45 psi
mph = 70 +/-
