Take it as a full unit. I have used this place in the past to straighten and balance the driveshaft. With new U-Joints and new center bearing I was at $500.
It needs balanced. Take both shafts in and make sure to have them marked how the slip splines go together. The 3 joints MUST be in unison or else it will destroy the driveline from the vibrations.Question: I already removed the driveshaft and replaced the u-joints before reading further replies...
Will L. I did not know to make any mark for timing. I've replace u- joints on my scout several times without any timing marks, and I, regretfully, assumed the same thing for this vehicle. How much trouble did I cause myself? I replaced all three u- joints, and I was going to reinstall, but not now. Should I go have it balanced, and if so, where do you take it, and do I take it as a full unit?
Yup. Got spun 180. Happens all the time, people just don’t know.I once was sent 80 miles north to remove the driveshaft from Ford 9000 4X4 truck. The center carrier bearing had went to crap and destroyed the rubber cushion around it. Brought the shaft back to the shop and replaced the center carrier bearing, pillow and all. U joints was fine. Another 80 mile trip to install it. That truck didnt make it two weeks and again destroyed the CCB. Another 80 mile trip and brought the shaft back to the shop. Looking it over real good and I could see no reason why this was happening. I told the shop super that it needed to go to the machine shop to get checked. The shop balanced the shaft, it was out. They also installed new u joints and center carrier.
Another 80 mile trip north to install the shaft.
Never had another problem with the drive shaft on that truck.
It will be money well spent. U Joints’ll love it much longer too, along wit splines, differential and transmission or T~Case.O.K. It is a 22 year old vehicle. Looked like factory u-joints (why I replaced them). Probably needs a balancing of the drive shaft as well. I'll do it... Thanks for the advise.
