Mike L.
Recruit
- Messages
- 128
- Reaction score
- 2
I designed and made the Mike L. cooler kit for the 5 speeds. It uses a Setrab cooler and I believe it's part number was 945 but do not remember for sure. It requires a different fitting as the threads in the cooler are different than the stock cooler fittings. The Earl's cooler has the same thread size as the stock cooler fittings and from the looks of the cooler it appears to have been made by Setrab for Earl's. Earl's sells Setrab units as well. If you look on the old site you can find where RenoDmax did a DIY for it. Both of these coolers do about the same job and the temperature drops are pretty much the same. If you do not mine a little work you can save yourself about $200 by using the Earl's cooler.
I have told everyone for over 3 years that you designed the brackets for the cooler Steve. When are you going to stop patting yourself on the back? Why don't you tell everyone how you tripled the price of the fittings to me from JiffyTite while telling me you were getting me your cost? By the way the Setrab # is a 925. Seems you can't seem to get your facts right most of the time.
Setrab and Earls partnered up on some of the coolers a while back and then parted ways. The Earls cooler is a good one and almost identical to the Setrab. The meah is different and the warranty is different. I chose to use the same cooler as GM,Prosche, HarleyDavidson,Nascar,Indy, and many other big names that want the best.
Coolers are nothing but a small sideline for me and I will allways have them in stock. For the guys that go way back to the DP's early days; I posted that I was going to make a cooler for my Alli and I did. I got a lot of pm's asking me to make more and I did. The Earl's cooler will do a good job. Buy the one that suits you best and don't forget that STEVE COLE designed the brackets on my cooler.
