- Staff
- #21
I'm not an 3xpert, just semi versed. If you have a pressure or dlutch problem, it's going to show when they ate loaded. When you drive it easy, it could be running minumum line pressure, and hold just fine, but when you get on it it would slip. The db2 problem would be if it is putting out to much power for the throttle setting, and line pressure is to low because of it. The same thing can happen with an optic bump. This one is going to require diagnosis to figure out. It may be a faulty epc solenoid, but if its been driven for long that way, there will be damage done to the clutches from it.
