DZZ71
"Living The 6.5 Dream"
Notice how it snapps like a gas jobber. Is that normal with the GM8's?
Okay well the original turbo (GM4) hit 17 pounds easy. So i swapped it out with a GM8 and with just the tubo master it hit olny 5 pounds. So i hay wired the wastegate shut nice and tight. I olny hit 9 pounds for a quick second. So i thought that there was somthing wrong with that one so i put my other GM8 i had on and it did the exact same thing. So its odviously not the turbos The fact is i shouldent half to wire the wastegate shut to get olny 9 pounds when i easly hit 17 before with the smaller turbo and turbo master........
Yes I have tryed tightening the turbomaster as tight as it will go and still nothing. And yes the leaver is pulling towards the truck. We tripple checked that it was properly closed. I can turn up the values on the GMTD scantech?
