Matt Bachand
Depends on the 6.5
Matt, the adjuster will turn much easier if the a arms hang. You should be fine as long as the end of the adjusting bolt is in the key and the threaded piece between is captured between the frame piece.
Ok. I'll look at it more to be certain later and maybe try to fix it.
It must be in the key, otherwise the t-bar wouldn't be holding weight I would think. I couln't see it well yesterday, but the pb blaster cleared parts up. It all had the classic 'one piece' rust look before, but the blaster is distinguishing things.
I have no choice but to drive it right now, so...........
Like I said, I barely applied tension to it, so if I broke it by doing that I find it hard to believe.
