Matt Bachand
Depends on the 6.5
Mods this is a duplicate post, but I'm unsure of the safety of my vehicle, so you can delete these threads all together when that is resolved. Thanks.
I was under there doing other things, and sprayed the t-bar bolts down with pbblaster they looked in good shape so I grabbed my 3/8ths ratchet and 18mm socket and figured I'd see if they'd break free, thinking I can't break anythingw tih 3/8th............................ They didn't move in the tighten direction, so I tried backwards to try to move the bolt free before I crank.
Well......................
I barely got any pressure on the thing and it poped a little bit. Upon looking at it the adjusting bolt is now angled instead of straight up and down.
I had it jacked up by the frame and front tires off while doing this as I was doing maintenance.
Said 'F ME' and finished up and took it for a ride. Around the block it didn't pop back in place and is still a little angle to the side on it. The adj bolt that is. Vehicle sits level.
There is a little peep view slot thing n the crossmemeber where the t-bars attach to, and I can see it angled there too. Was hoping with weight on it it will pop back where it should as I barely applied pressure to it (loosen direction).........
Once again had vehicle jacked up by frame and tires off so they were as unloaded as they get.... Probably why this happened???
Well, is it safe? How do I fix??
Thanks!
Thanks!
