Yachtcare
Recruit
- Messages
- 173
- Reaction score
- 2
Truck died while idling outside AZ this morning while I was in getting crossover gaskets to fix a leak that developed there yesterday. No start, good crank. Had codes 13, 36, and 68. I've had the 36 and 68, with no overdrive for several weeks now, but truck was running well, with only an occassional fishbite. I use tcw3 spec 2 stroke, every fill up.
I pulled the shutoff solenoid, and tested it using the battery charger. Plunger went in and out like it is supposed too. It is a solenoid replaced about 2.5 years ago. Decided that probably isnt the issue, despite the code 13 that showed up for the first time today. But wondering if there could be an electrical fault. With ign power off I ohmed the wires for the solenoid, doesnt seem to be any shorting there. But could use more info on how that system operates, and at what voltages.
Got truck home on a hook and checked voltage to IP, good (12.78 V). IP is a green tagged 5068. Checked extension harness, as well as a spare, both are good. Pulled and checked all fuses for good measure, and all the connectors on the IP, except the big one at the back. Will work on that tomorrow, hopefully I wont have to pull the intake to do so.
Did lift pump test, have good air free fuel from the bleeder and T handle. NO fuel,when I cracked the nut at #1 cylinder.
Went to local Stanadyne dealer. They were kind enough to lend me a PMD, same model number as mine, but with a #5 resistor, opposed to the #9 in mine. Not sure if that would cause an issue. Tried both PMDs with both harnesses. Same symptoms persist. I did clear the codes, and none have recurred, but of course the truck hasnt run yet, either.
Batteries were getting a bit tired by sundown, so put the charger on for the night. Will get back to it in the AM. Although I cleaned all grounds in my annual July maint program, I'll go thru everything again.
Anything else I should be checking?
