Mudbath
Old Smoky
History of my vehicle
Always had hard to start when cold, would start run like crap for a few seconds and smoke like a SOB then something would change and instantly run smooth and clear up the smoke (blue smoke) Then would start like a champ after that as long as it had run for a bit.
PO had it into GM many times and it never was properly resolved, I have had it for 4 years now and have done the following ... Heath tune, Heath lift pump, Heath TM, Engine coolant sensor (in Thermostat housing crossover) Heath PMD kit, TDCO offset was @ -1.94 and recently drop it down with Engh's GMTDScan Tech to -1.75
Now I just did the HG on this truck and while doing that I replace the CPS as it looked original and was in rough shape. Did OPS while I was at it too (not relevant to this)
After running it a couple days I am getting even harder starts than before with more smoke, once warmed up much better. It is setting a code 34 DTC and engine light will come on and go out. So I warmed it up and thought I would recheck the timing and when checking DTC there is the code 88 which clears then comes back when rechecked.
I tried to do the Timing Set and Learn but both cause engine to stall. (TDCO shows as 0 and once got it to go to something else which was the undesired -2.02 setting the code 88) The Desire and Actual are sitting at 11.7 (use to be lower but can't remember number, 8.5???) which confused me because I never changed the IP position. While doing the HG job I also replaced the water pump and check the chain by moving the crank and watching the camshaft and IP gears, things were tight there. I am starting to think that PO had TDCO set when the CPS was bad and now that it is new I am getting timing problems OR I have a flaky CPS (Standard)
Got any Ideas for me? Do you think I will have to turn the IP a bit to get that 11.7 down? Which way and what is a good base timing to aim for if this is what has to be done.
Hopefully Buddy the timing Guru is listening!
