- Staff
 - #21
After reading this thread the EE in me comes out. I am thinking if I could take a oscilloscope and trigger off the crank sensor while looking at the IP OS and crank it over, measure the time, then do some math I could set the OS position like it should have been on the IP test stand. I realize not everyone has a scope handy, piggy backing into the connectors is a pain, but it should be doable. If you wanted to set the OS out of the truck, a cheap test stand to do this on could be made from a junk block with a crank, flex plate, starter, cam/IP drive, crank sensor, some wiring, a few parts to energize the sensors and nothing else. Yea I'm nuts.
The optic sensor timing has nothing to do with crank timing. The optic sensor reads a disc inside the injection pump. This disc tells it position and injected amount by how much of the disc and when it reads it. Without a test stand, the closest way to set an optic sensor is to install a #5 resistor, do a TDCO learn, and then check your idle fuel rate. If it is reading roughly 8-10 MM3 of fuel at a hot idle, it is pretty close. If it is reading high or low you will need to bump it slightly and then recheck it. The test stand checks for proper OS position in relation to the spinning disc with the pump at a specified timing position, and then it tells you how much fuel is being put out so you can put in the proper calibration resistor in the PMD.
