NVW
Messed with a bit today, it rained. It would rev to 1000-1100 rpm like before. set timing a few times. Came back later and it would rev up in park, but only with at least 1/4 throttle. ( why I thought the APP) runs rough but when it revs it is smooth.
I then found later, in park or neutral it would now only go to 1000-1100 rpm, put it in drive or reverse and it will run like a raped ape. It idles like it is missing on a couple cylinders, but runs smooth under acceleration. I now have boost, at least 1/4 throttle is needed to get it to go.
It also idles at 1000 rpm, if it is in gear and you let it pull down to 600 rpm it will stay there until it is revved up again, sometimes it just idles at 600 rpm.
FYI, the first thing I did was grounds I get black smoke now instead of grey when it is warm. (before it just smoked grey, no boost)
I am going to try a container of diesel and Sea Foam next.
I have never been stumped before.
