No, but that would be cool and very expencive I bet. Maybe do a sas in the rear:smile5:
Thats good to know. Just eyeballing them in the junk yard I could not see that difference. Other than the 1/4" i believe they are the same as 1/2 tons.
Just when tou need to make a serious hard evasive turn, the knuckle has been modified, leading to a too tight turn that breaks the spindle and rolls you over at high speed leading to th.... well you can imagine all the rest of it.
What options trigger 6 lugs on a 2WD? crew cab and longbed plus maybe trailer tow package? :confused5:
I was gonna post the same thing, but thankfully read ahead
Using a better box will help, but if you find yourself rubbing the frame you will need to start using different offsets.
