3500GMC
What T F, over
Any pics without the wheel on?
No, unfortunately. But, if you look at where the axle cap (about 3/8" thick) is bolted onto... That cylinder that sticks out of the wheel is part of the drum.
EDIT: Originally typed "hub" above - changed it to "drum".
Oh, to maybe better explain (or maybe not!)... The drum looks like a men's top hat, except the top is hollow.
It would save work for sure. I'll check your link next.Here is what yours should look like (minus the wobble) when the drums are off.
http://www.youtube.com/watch?v=LdfLye8NIn0
This is my '93 with 13x3.5 "JB8" brakes.
I'm just trying to save you some work.
Question, though... If it takes all that work (BFH) to separate the hub and the drum, isn't it just easier to take them off as one piece? Or am I still missing something... maybe my light bulb is a CFL and it isn't fully warmed up, yet?
.... I applied antiseize to the mating surface between the drum and wheel. Would that be OK for the hub to drum contact area, too?
,,,, very fine, hairline cracks in the pad contact area,,,,worth saving?
I think they are original. Part number 15622390 is stamped on them.
That pricing at AZ is pretty cheap! I'll check the local NAPA on Monday to compare (hopefully they have something made in the USA). I can't ways do it, but I try to buy USA when I can.
However, at that point I think I'm starting to approach the ballpark of getting a salvage axle with discs on it. I've only looked quickly, but I think I've found them in the $400-$500 range. Well, maybe not entirely, but close enough that it has me thinking.
Maybe I'll take the hub to a place that can turn it and see what they think?
When I can just get the drum on and there is a very slight drag as I rotate the drum by hand then it's good to bolt the wheel on. Do the other side and you are good to go.Or do you adjust the brakes by feel - tighten them, then release when they just stop dragging?
