DennisG01
I popped the drum off to take a look at things. I don't have the special retaining nut tool so I tightened it back up in a similar fashion to the way I do it on trailers - "by feel". For this nut, I stuck a small Torx screwdriver in one of the "holes" of the nut and used that to rotate the nut tight. The hub spun freely and there was absolutely no play in the hub when I shook it. Then I tapped the nut a little tighter with a hammer (probably made it turn about 15*). I then backed it off until the keyway lined up (a little less than 15*). Still no play in the hub. I put the wheel on and there was still no play when I tried to rock the wheel back and forth.
Does this sound alright?
