ak diesel driver
6.5 driver
Leroy can get them now. Made by Milodon IIRC.
Is that the pan which allows for a P400 install over 4wd differential?
If so, how much they want for one?
I have run uncoated 6.2 NA pistons for better than 60,000 miles at EGT's that would make most pee their paints and ruined engine oil.
I don't loose sleep over uncoated pistons.
You are good for at least a 1/2 turn on the DB2 pump with the ATT setup. You can safely go 1/4 turn on just about anything...
