iamdave0887
Here Comes Chaos.....
Maybe the turbo is weak ?? Could be a boost leak somewhere with that hihat setup ??? I wonder if an F intake would help.
It certainly doesn't sound weak. Whistles like mad, and the whistle picks right up with engine RPM. When cruising down the road it's not pumping soot so i knwo the turbo is doing something. It may not be making boost, but remember boost is just pressure against closed intake valves. It's not everything. CFM matters a lot too.
they were built to run 10 psi balls to the wall, WOT, so cracking 3.5 with me driving conservatively doesn't seem out of spec.
Going to try to modify a spare 6.5T CDR and see if i can do something about the blowby. Stupid 6.2 CDR isn't doing a damn thing with the turbo setup.
