cub124
Half Moon Detroit #1
To those of you who want a cheap and powerful turbo choice!
Engine
I started with a red block, put ten over fel-pro head gaskets on with ARP head studs and 1983 or newer heads. I used a 6.5 manifold and slotted it for the turbo.
Exhaust
I used a 90* 3/12 inch bend then immediately reduced it to 3 inch due to pipe clearance issues. This isn't really a big deal because the hole for the v clap from factory is 3 1/8", if I would have known this before I bought the 90 I woulda just bought a 3" ID/OD 90* after I fabbed it was painted and wrapped in heat tape.
Boost/vane controller
The controller is mechanical with a pneumatic waste gate actuator controlled off of manifold pressure and it is adjustable via boost valve. The turbo intake is 4 inch made from exhaust pipe and the boost side is 2 1/5" I used red RTV on the turbo exhaust flange.
Fuel
I "fed the beast" Put 3/8 rubber line fitting from the out side of the filter and on the In side of the pump but I couldn't put regular fittings on they had to be drilled out first! :hihi: on the filter side I drilled out the aluminum housing and carefully tapped it for NPT. Then the mechanical fuel pump was tossed for electric 6.2 fuel pump 10-14psi. I had to move the large filter for turbo clearance and fire issues from the firewall to the side of the fender. The electric pump was placed after this due to the warranty may be void without a filter but I may end up placing it before the filter (its easier to push than pull) As far as the high pressure pump the 6.2 one worked fine, as of right now its maxed out which is more fuel than needed. It will probably be turned down 1/8 of a turn off of maxed out. It could easily get the turbo past 20 psi if I wanted.
Pictures...
PS I do have an idea on how to open the vgt on highway via air pump or electric actuator I'll be posting a diagram tomorrow of the pneumatic way.
Engine
Exhaust
Fuel
Pictures...
