L98TPI
The 4L60-E however... Aluminum VB...?! You gotta be kiddin me... :rolleyes5:
But remember the 4L60E is computer controlled. The only valves that are dynamic are controlled by the solenoids. Pressures are modulated by the PWM motors. I bet there is a bit tolerance for wear there, the all hydraulic control does not have. Still there are kits to rebuild the valve bore for the E's.
Yea the TV and the TCCV 's some times need the TransGo or Sunnax kits. They are not to pricey, might as well do it and have it over with. I do like the ones you don't have to ream for. They do a dance compared to the shift valves. :banana:
