ak diesel driver
6.5 driver
just went back and reread, your fuel pressure guage is pre filter so it doesn't totally eliminate fuel supply. check filter, screen under filter, and if IIRC there's one more screen in the IP inlet
thanx both of you. i suspected the pre-IP screen because i had that prob with the 93. wasn't aware it would throw codes though. that will be looked at Sun. Jorge6.5, what is the 'in line filter harness'?
fuel filter is new so don't feel like that would factor.
AK, what do you mean 'screen under filter'? where is it? there is one inside the FFM, goes on the center around the heat element. i will check that because i forgot about it. i have a set of gaskets to get the intake off/on, kind of ironic that i recently sold a few sets.
seems if i keep a part for years, it only gets in the way, but as soon as i get rid of it, it's needed.
