And that too can be measured and monitored as You drive.temperature could also be tested
but the lower amperage is a given
That's not due to heat, that's because of battery charge condition. You see 14+V to charge the batteries due to discharge from glows/cranking, then 13+V to maintain once the batteries have been charged back up from starting.you shouldn't see a decrease in amperage output while running down the road even with the larger pulley, only at idle and with a load like with the blower fan on high and the halogen headlights going.
as for temp. I have not ever measured the temp on my alternator (AD244) but I do know that in the mornings my volt gauge is up at 14 and after a 30 minuet drive I have noticed my volt gauge down to 13 or so. So heat does equate to a lower output.
Yes, that is true. You loose the advantage of the better alternator.this is an AD244 alternator 180A output, with 100A at idle, this amperage is due with the over spin from a very small 42.60mm pulley.
now, if i swap pulley with a 57mm pulley, output amperage comeback to stock amperage 130/150A - 140A is acceptable, which is the amperage I expect
going with a more larger 62mm pulley, it will further lower amperage, it's a given, you don't need to test for know this.
a lower amperage is not what i need
