Crankme69
Hey Forrest nice to hear from you & wish you all the very best...stay in touch
Hey Forest nice to hear from you & wish you all the very best...stay in touch
Does it matter if its lever vs push button in terms of "on the fly" engaging? Or have I just been "chancing" it by engaging while moving with my mechanical transfer case?
Oh, and besides the occasional off the beaten path/farm drive...I typically use it for driving through blizzards on the highway (45-60 mph) and on really soft or bumpy gravel roads. (I like my theory that if all 4 tires are turning, the front isn't being "pushed" into bumps. Probably flawed...but I like it anyways, haha. An excuse to use it when I don't need to.)
Why would LLY compression ration be higher than LBZ? I mean, theoretically, why would GM lower the compression ration? Cheaper parts with less pressure?
Also, on electrical transfer case engagements, is the line of power go from battery - switch - motor attached to transfer case - transfer case? Is there a way to manually over ride the transfer case if something were to happen to the wiring?
