jrsavoie
Recruit
I've never got a gauge set up. I've never been to to the point where I needed one for diagnostics before. Not that I didn't always want one in each vehicle.I always thought that should have been an OEM gauge.
The lift pump does put out a steady stream of fuel out the drain T while running.
I won't be messing with the Suburban now, til I find a transmission and get some other stuff caught up. I'll put the transmission in first and then get to checking the engine on the suburban. Unless I get a chance to go through the Suburban first. But it's on the bottom of my list right now. I'd like to check the glow plugs, compression and injectors.
LP going bad or not getting a full 12volts can cause the surging. What psi is your LP putting out?
