- Staff
- #21
Missy is, as usual, dead right on this one...
Codes have a nasty habit of cascading; one problem causes another, and THEY tell 2 friends, and so on and so on...
Your initial code 17 was the OS fault; normally, when a 17 arrives as a result of poor opacity or fuel lubrication (yeah, I know, it shouldn't, but it does), you get 17, 18, 35, and sometimes 54. So the 68 and 86 were strange, here; not a 'normal' OS fault.
Finding it unplugged is not normal... that probably cascaded the whole works.
The clue here, incidentally, was the 17 re-appearing without cranking.
The problem with dealerships is they read the damn manual and assume it's all right, so if they get 10 codes, they down the engine and change 10 things, all at once - makes for nice repair bills.
Sometimes, you fix ONE blabbermouth and you can stop ALL the gossip in the neighborhood... likewise, fixing the main fault can prevent the cascade of DTC codes.
Faire's Rules;
1] - Always do the cheap/free stuff first. Grounds, connections, tests for LP, fuses, etc. If you do a major repair and the problem is still there (and turns out to be a loose wire) you're gonna be torqued.
2] - Fix one thing at a time - start with the (logically) most likely suspect (keeping in mind the cost), and then test. Did that fix other things as well?
3] - Use the codes and diagnostics with a little common sense... if it isn't logical, it probably isn't the problem.
Faire's Rules;
