Odd thing my speedo is off by 7 mph higher than gps, yet speed in PCM as seen with scan tool is spot on match with GPS and with those radar speed warning signs same as it was when I had the 265-75s it came with from factory, my height is a littler lower factory 1870# rated rims were 7" wide and now I have Classic MT 8" 3300# rated rims. But speedo with the MT rims 265 vs 235 off just the same as with the factory rims. Bill says some tucks the speedo needle was installed off just a little on the pin I could take it off and try to make it better, but it could also be worse.
I had that same problem all of a sudden one day with bus 1. I can't remember now if it was 5-10 mph off. It was spot on, then one day... boom. Dead on with OBDII recorder that I used to plug in.
Still gathering thoughts here on this tire size situation.... So, going with 235's is going to reduce rolling resistance, and going with the 85's is going to give me the extra circumference that I need to reduce engine RPM without having to re-gear the rear. Some shot gun math this morning while researching looked like it would effectively change it from a 3.73 rear to a 3.57 instead. 235's will be a smaller patch of rubber hitting the road, (better more wet than dry as I read it.) and raising up to a 85 I have more side wall, and a bit more slop in handling?
On a whole 'nother note... we have exited the bus era in our family last night. Bus 2 has found a new home in a new driveway. I have one very distraught son who hated to see it go. It was painful to see him so upset about it too. I too hated to see it go. There is only room for 4 vehicles in a two vehicle driveway.
The Suburban is still sitting loud and proud in the driveway. 168k on original IP too.... tick, tick, tick...
