jrsavoie
Recruit
MY copper T's have absolutely no restriction and the heaters work fine. Seems contradictory
also now is the time to check the a/c evaporator core and see if it is covered with dirt,hair,small children ect..
OK. Now I'm confused again. I thought it was just going to come down to switching the two lines around that go to the two cores since my rear heat used to work with the current Tee's (they do not have restrictors - I am 100% positive). But, it appears Dave has the same green hose going to the front core -- #2 -- (which I'll assume does not neck down... just like mine). The hose that is currently in the position of "rear core inlet" -- #3 -- does neck down.
So, just to clear things up (for me, anyway) -- according to the numbers in this pic, what sections of the Tee's are supposed to have restrictors?
Ferm... I think you mentioned this above somewhere, but you're 100% positive that those Tee's you have do have restrictors? I just keep coming back to not understanding why everything worked before, and now it doesn't.
Unless, could my restrictors have fallen out? While the engine was out of the truck and everything was disconnected? I mean, are they an actual part of the Tee, or could they come apart?
I really appreciate all the help! Oh, I dream of $.99 diesel, too!!!!
[/IMG]![]()
I confirmed with gm parts book that the supply and return "tee" fittings are identical p/n's. Thus, the orifice part of the "tee" is at position #3 and #6 restricting flow to and from the rear heater. I forgot to measure the size of the orifice in the plastic tee. However, the orifice in the QD is approximately 0.260" diameter.
