Pillow
Recruit
It is dead or darn close to it. It sounds horrible.
What it could be:
- Bad injectors? Doubt it since they were replaced at 150K with new Bosch units.
- Cracked crank? Dunno
- Smoked a piston? Dunno
- Head gasket? No smoke in exhaust and no coolant loss, also oil is clean in pan.
- Crossover pipe issues? I doubt it.
- Rocker arm issue? I doubt it because the noise seems all over instead of an issolated tick. Granted I think the sounds are more from the drivers side bank of cylinders.
When you rev it up quick in neutral is smooths out and sounds normal for a split second. Then revs down and sounds like hell again. When driving it sounds like hell the whole time.
Good oil pressure and coolant temps.
... Any good deals on new longblocks? The wife wants another 100K out of this truck. And she does not trust rebuilds. Any good shops that want to build a Navistar block with Scat crank? A new Burb is like 40K which is about 30 more than I have to pay. Anyone have the Lottery numbers handy
What it could be:
