Thankyou denata,. never had a problem with cruise so i don't know what or why it has been modded, thats a sleeping dog right there.These are the contacts for the cruise control system.
Can you explain your reasoning for that?? i unplugged it and its working,. If it wasn't working KOKO would not initiate due to a fault code,.It also seems to me that it is working because KOKO does initiate at 171 deg everytime the truck warms up,. very frustrating,.From what you've described I'd try changing the crank sensor
Just re read what i wrote just make sure,.. motor was idling, i unplugged OS, motor ran rough and as i said it was hunting for its idle speed, then as i said it settled down and ran quietly,.So when you unplugged the OS and it was running on the CPS you said it ran erratically. It should run smoothly. It should run smoothly on either sensor by itself albeit with less power because it is in limp mode.
