The truck was running great until recently.
I have the dreaded Code 35 injection pulse too short but it only comes on during acceleration.
It started when the wife shut down the truck prematurely and I had to start on a little bit of cold veggie. I don't know if this is coincidence or the cause of the problem.
Funny thing is that it now runs fine once it switches to WVO. The code goes away completely and the truck has no issues on WVO. It also runs fine once I purge and run only diesel but only after I run WVO for a period of time.
I suspect there is some issue with the optical sensor from reading several posts so I have tried the following to diagnose or fix the issue:
Installed clear line and checked for any air bubbles-none present.
Ran Lubro Molly diesel purge through the IP via the lift pump (bypassed the fuel tank and ran from a coffee can).
Ran 1/2 tank of diesel with 2 stroke oil
Ran Powerservice
Filled the tank with fresh new diesel
I checked the pulse width with GMScan basic and when the code is present pulse width locks at either 1.95 or 1.99.
When the code is not present the pulse width changes based on pedal position.
Any help is greatly appreciated.
Ran Powerservice
