Just wondering if anyone has replaced their stabilizer shock? I am going to replace mine since it is leaking and I'm sure it's toast and was wondering if people were going aftermarket or OEM...
I looked at mine the other day when I installed my centerlink
All I can say is it is a pain to seperate it from the centerlink. You can get on the nut with a socket, however if you have an 18mm ratchet wrenh it will be a breeze, kinda.
Then you gotta find a way to pop it out. I couldnt get a hammer in there to save my life.
A tie rod fork would work best, but I was able to get a pry bar in there to finally get it out.
Ya I guess. Ive pulled a lot before but this truck is completely different.
My truck has changed a lot since last year and its gonna take a lot to get used to.
I usually just sit in my truck in line and space out till its my turn. Afterwards Its a huge relief that I made it down in one piece.
But youll definately see the "dieselholic" up there. Im hoping to place in the middle of the class, as long as a bunch of Furds show up again I should be fine.
