Husker6.5
That motorhome of @Leekeeler's looks very similar to Jody's. His was DS4, side mount turbo (I know, we had to pull the doghouse in the dark, at night, in a gas station parking lot right off an exit on I-80 somewhere in the middle of freaking nowhere Nevada, so Jody could unplug the harness from the failing PMD, plug in an extension harness from Heath, snake that out the doghouse, replace the cover, then plug the extension into one of Bill's new style PMD's mounted on his skid plate heatsink, which we laid down in front of the copilot floor heater outlet so that it would have some air flowing over it). Jody's is a P3x series chassis and I assume so is Lee's.
If you remember from Jody's broken rocker leading to a new motor thread, Peninsular built a custom set of headers/up pipe assembly to center mount the Peninsular turbo and a custom down pipe. There was also a TON of room (like two feet) between the front of the radiator to the grille to put an intercooler on Jody's.
