treegump
Romans 3:22-24
Well - first things - I'm purchasing a used starter (lifetime warranty from autozone) and used injectors from Ted Reminder, but I wanted to check with you guys too.
Problem: ______Cranks several times before starting (see attached video (sound only - my garage isn't very well lit) and attached pics of starter)
- Year: _96_
- Truck model and class (ie: c2500) __K2500__
- Automatic or Standard __Standard_
- Mileage: (indicate miles or km) __164000__-bought the truck at 155k
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _DIY TM, Glow Plug override, High Idle, oil cooler changed, banks exhaust _
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _F_
- Ambient outside temp: (indicate *C or *F) __30* F (but was happening when I bought the truck and it was 80*F__
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___? - BP or Shell - stopped going to Flying J______
- What fuel additives are you using? __Put 2 cycle (40:1) in my last tank and have put Power Service in it and Lucas before that_
- Where are you located? __Northwest Indiana__
- Air filter _less than 4k miles ago__
- Fuel filter __same time as air filter__
- CDR Valve? __less than 10k miles ago__
- Coolant – last flushed/replaced at __unknown___
- Oil – synthetic/regular, changed at __4.9k miles ago__
- Batteries – state of charge, (matched set) replaced at __12+ volts after engine is ran for a while - 12 volts when truck is cold = battery charge is good__
- Battery cables and grounds (removed, cleaned and tightened): __everything has been done___________
- Glow Plugs - how many miles on them? ___less than 10k_ What type? _60g____________
- Injectors - last changed at __unknown_____________
- What were you doing when it happened? ___always has happened___________
- How was the truck running fine before this problem appeared? ____see above answer_________
- Has this problem ever happened before? ________yes - always_______________
- Describe any related factors that might be part of the problem. __a previous owner did crappy own electrical repairs/additions__
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _N_- I asked autozone if they could and they said no, they couldn't__ And? ________
[FONT="]
[/FONT]Diagnostics:
1] Starting:
1a] Does the engine start? _Yes________
1b] Does the engine crank over? ___Yes_____
1c] Are your batteries fully charged? __Yes_______
1d] Have you removed, cleaned, and tightened all battery connections? __Yes______
1e] Does your Wait to Start light come on for a time? How long? ___isn't that the same as the glow plug light?______
1f] Does your glow plug light come on? __Yes - 8 sec and then blinks on and off about 4 times on cold days_______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? __not while cranking - only when it first fires - a large greyish cloud (could be black - haven't seen it leaving the tip)______
1h] Does the Service Engine Light Glow during Start/bulb check? ___nope_____
2a] Can you hear your lift pump working? ___yes_________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___yes______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___haven't done - but at the fuel filter there is________
2d] Loosen an injector line and crank the engine - does fuel come out? ___haven't checked yet______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___no________
3] PMD / IP Issues (everything unknown)
3a] Location of PMD (on pump, on intake, remote mounted) ___um...not sure - but i'd have to guess on intake___
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____no________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) __no - but it has "hiccupped" a couple of times but not often enough to track down a problem or source____
4c] Does pouring cool water over the IP seem to help with restarting? __never tried it_______
4d] Is stalling momentary (engine recovers)? ____no_____
4e] Does SES light come on when engine hiccups? __no_______
4f] Does cruise control quit working when engine hiccups? ___not sure - i've never had it on CC when its done it________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? _its so quick and sporatic i haven't noticed__
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __hm...not sure_____
5b] Any bubbles or oil film in coolant overflow tank? _no______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____not that i've noticed______
5d] Excessive white smoke from exhaust on cold start? __at first fire - but not after that_______
5e] Excessive black smoke from exhaust under hard acceleration? _____not anymore _____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? __boost & egt_________
6b] Maximum boost under load? __so far - 9.5__________
6c] Have you added a performance PCM (reflash) or Chip? _____no_________
6d] Have you changed exhaust / downpipe / crossover? ____about an inch larger than stock after muffler - bank's exhaust____________
6e] Wastegate – mechanical or vacuum (OEM)? ______diy mechanical________
7a] Single or dual thermostats? ___huh...not sure (how do I check)_________
7b] Have you replaced them lately? Manufacturer of replacements? ___obviously no - was going to order 2 from kennedy - wanted to know if 180 or 190 and how to find spring loaded bypass vlv?______
7c] Have you pulled and cleaned Radiator and coolers lately? ___no - on my list to do_(new oil cooler and lines)________
7d] Have you replaced the fan clutch? Manufacturer of replacement? __no______
7e] (winter) Have you tested your antifreeze? Good to what temp? __no-but checked yesterday and the top 1/16" was frozen in the overflow_______
7f] (winter) Are you using a winter grille cover? _no-engine needle goes beyond half way in normal driving conditions__________
List and describe any other factors which are not addressed in this checklist. Pictures of starter included and sound for me starting this morning. As well as pictures of my engine - but can take additional top/side pics at lunch today. There is coolant on top of block on passenger side - but I think its from the hose connection. There is also coolant on the driver's side where the cord ties into the motor - but there is a short there as well, so if the heater heats the coolant, then i plan on just sealing that up (if the starter/injectors fix the problem). The pics might not due justice - but the connections to the starter look just as bad as the starter.
- Year: _96_
[FONT="]
[/FONT]Diagnostics:
1] Starting:
4] Stalling Issues
5] Running Issues
