Husker6.5
Try using some Locktite red on the threads of the two starter bolts and that they're torqued down to spec. With the brace in place and everything torqued correctly, the starter "shouldn't" vibrate loose. Problem is that if it has done so several times, the threads in the block may be worn slightly and thus the use of the Locktite to help fill the void and prevent them from working loose again.
