Nosferatu49534
My thought was to use that because I still have 10ft or so. Its super flexible. Plus with the adhesive heat shrink it should be water proof.
I don't get that. It seems to me you'd want the same size for both cables.The way I understand it is you need the bigger wires for positive: pos to pos, pos to starter, pos to alt (the original have fusible link).
You can use #4 for negative, not a problem.
But some people have been using the big wires for positive too.
