Husker6.5
Yes, it does. In essence, what Leroy's pre-wired kit does is instead of having 10-15 amps of current flowing through the contacts inside the OPS to power the Lift Pump through the light wire gauge OEM harness, the OPS now energizes the coil inside the relay (< 1 amp) and the 30 amp relay takes its power directly from the battery to the Lift Pump using a lot heavier wire gauge than OEM. This reduces voltage drop to the LP, eliminates contact points failure in the OPS, and greatly extends the life of both the OPS and LP! Everything in his kit comes pre-terminated, plug and play, all you have to do is pull your power for the LP from the Aux Accessories terminal stud in the underhood fuse block.
