indybeck
Yes, TD spare was under hood on SS heat sync, but immediately got moved when I bought the truck. The truck ran fine with it before I moved it, and then I purchased a new PMD about a month later for peace of mind. Truck still does it with either or PMD. I made the extension harness, and in a week or so, I will make a no splice harness. I took the harness off, and checked for bad spots in the wire, and wiggled and jiggled splices and connector pins. KOKO was done with truck warm at 180-190 degrees. I do have one readiness code that will not go away with a scanner.
