Matt Bachand
Depends on the 6.5
It will have to wait till I get back I leave tomrrow to be gone 4-5 weeks.
Good luck and have fun! Road Trip!
I'm not sure what a Walbro or Racor is or a filter manager, I'm assuming some sort of specialized aftermarket filter? I'm only really concerned with the lift pump, I checked it today, key on/engine off and it was making a throbbing noise/felt more than heard, didn't feel right. Almost like a very muffled clicking. What's it supposed to sound/feel like? I was expecting more of a steady buzz.
My 2 cents.
I had very simular conditions. Bucking under a load. I replaced filter and still had problem, the LP was new just a month old at the time. The problem turned out to be that the line between the LP and FM was almost totaly pluged. I blew it out with air. You might want to do that also while your LP is off. Takes about 10 minutes Just disconnect the rubber hose going to back of the FM and the line coming from the LP. I slid a hose over the line at the LP and directed it toward a bucket. Then just hit it with the air on the FM side. Use a clean bucket so you can tell if anything comes out.
You can also blow air from the LP back to the tank. Make sure fuel cap is off before blowing air to tank.
Think it would hurt the lines to spray carb cleaner in the lines before blowing air through them? FM - LP line is the one i'm referring to.
