buddy
Active Member
Thats where a scanner would come in handy, so you can see what the MAP is reading the atmospheric pressure is, should be about 14psi with no boost. and monitor evereything real time.
X2Thats where a scanner would come in handy, so you can see what the MAP is reading the atmospheric pressure is, should be about 14psi with no boost. and monitor evereything real time.
Put a resistor across the IAT sensor harness, you would fool the PCM to thinking its only 150 if you put in a 500 ohm resistor.
Maybe you shouldnt go 90MPH with 4.10 gears
What size tires do you have on there, noticed you had newer wheels. If you put on some massive tires the truck might not realize how fast it is going and you can mess up tranny controllings.
One thing i can think of that would cause it, When i put my boost gauge in I put a "t" in the sensor hole so i could have a barb fitting for the boost gauge line. Could that being raised up above the intake manifold get enough engine compartment heat to make a difference?
Hmmm, so you split the airflow at the MAP sensor, and you are fooling the PCM on the boost amount. That could affect its measurements and your sensor's. Put that back to normal. Just get an $8 tap and put the boost guage in somewhere else.
Anyone in West Michigan with a scan tool? I'll buy your lunch!!!!!
This is going to be a pain in the butt if i gotta pull a 4k trailer 600 miles with a half alive 6.5L
