- Staff
- #1
Guess I'll post up my luck so we can have a duramax problem post around here. I've picked up a slight vibration in my BURB just off idle. I noticed it when I bumped my idle speed back up to 680 from 600 trying to make the A/C work better in traffic. When I dropped the idle speed back down, I noticed the DREADED haze at night in cars head lights when stopped. Plugged in my V2 and all my balance rates are +/-1.2 EXCEPT #8 is sitting at a consistent -3.8-3.9. So at face value they look good but #8 is borderline, BUT to anybody who's read my write up on corrected balance rates know's, you have to also look at the fuel rate. Well mine is sitting at 6-6.1 at idle. So that means I have to add 2 to my balance rates to get corrected numbers, all of the sudden #8 is sitting at a -5.8-5.9, and I don't have a single injector with a + balance rate.
This is what I get for talking good about the updated sticks a few months back saying how mine were doing great at 70 K miles. I have 7 in spec, but one is a good ways out(it's only being commanded on for 2.1MM3 of flow when it should be commanded on for 8MM3 of flow). So it holds true with an LB7, it's not IF, but WHEN they will go out. For now I bumped my idle speed back up, and played with the timing some to minimize the hazing at night in the headlights, but I gotta get ready to do my injectors. I could go in and do just #8, but I can tell from the balance rates with them ALL being negative, it's only a matter of time for the rest. And with the track record of VCO's, I'll be going back with SAC's next time. Even the wife told me not to do stockers, but to spend the extra for the SAC's in hopes I won't have to do this again in another 70K miles.
So here around Christmas time looks like I will be doing injectors in my BURB this year. Last year it was front end, steering, and brakes. So much for the "TOY" I was looking to build next summer. I had been setting some aside in hopes of getting a 2 door tahoe to build up for a play toy, but that money will now be going to buy a set of 45 over SAC's for the LB7.
