Acesneights1
4l80e is a better tranny stock but you can do full billet suncoast 47re and it will hold up just fine. You put a worked Cummins behind anything stock and it will blow apart.
Smarty...That is what you need. Rich (Cumminalong) sells them if you need one.
JKAUTO has a CUMMINS BURB. The 4L80E stock can't come close to holding what a 47RE can stock, just facts. The 47RE can and has been built to hold 1000HP+, the 4L80E will self destruct even fully built after about 400HP behind a diesel in OD. They are pretty tough in 1-3, but 4th they are weak. Transfer case isn't an issue either if you have a DODGE and GM in front of you to make one out of. You take a DODGE transfer case and swap it out with the GM output shaft with tone wheel and use the GM rear bearing holder as that will let you thread in the OSS to make your stock speedo work. You can use the bread truck adapter, but that will rotate the tranny 7 degrees so you have to put the engine in on an angle. The DESTROKED adapter will put it in straight, but will cost you over $1K for the adapter plate and such to hook it up plus a FORD 6L starter. Then throw in the cost of a fully built 4L80E with a billet converter and your trans controller and you could have bought a 47RE and had it built up.
Also THEFERMANATOR wouldn't I need to use a 47rh cause the re is electronically controlled? I PM'd those who wanted one.
If you'd like, I can give you a phone number of a friend of mine who lives/works in American Falls and has a Suburban with a Cummins in it, modded like wildfire. He did the conversion himself, and would be a wonderful resource for you.
Ferm, I'm pretty sure I've read that a properly built a 4L80E is good for 700Hp, I beefed mine up for 18K loads, but I"m guessing only 275-ish Hp to the flywheel in mine.
Last time I talked to Ron @ Suncoast they were close to having a really beefey 4L80E, GMCTD running a Cummins truck now had some issues he didn't like with Dodge trans, I'll try to hook up with him to see if he can post what it was there.
I am located in Idaho Falls Idaho, I will get some video up of the truck running, like I said anything from the 6.5 including the 6.5 is for sale!
ADAPTER PLATE=$795
FLEXPLATE=$625
STARTER=$129
$1549 just to get it bolted up to the CUMMINS, not to mention the $1K for a billet converter, and whatever a GOOD solid build will cost you on one with billet shafts, heavy duty planetarys, 4L85E upgrades, and along with the 99+ improvements inside of your 4L80E to get it to hold up. It makes that DODGE tranny with a build look better and better.
