iamdave0887
Here Comes Chaos.....
i noticed it after pulling into the fuel station. its very very faint but its there. i can almost see through it and i do have to look for it if not under really bright lights. no loss of coolant, no exhaust pressure in the coolant(i released the normal pressure from the 45 minutes drive home from work and started it back up and the hose wasn't stiff at all). i'm wondering if at 167,xxx miles if the injectors are starting to fail. they are well overdue. truck runs like it always has and doesn't sound any different. slight white smoke upon startup but no clouds or chugging. it starts up and runs on all 8 all the time. i've got no idea if the injectors are original or not. any thoughts?
EDIT: if i bring the RPM up even a little bit(1070 high idle switch on) the smokes gone.
