GM Guy
Manual Trans. 2WD Enthusiast
If its OK, I would like to get first on the list for the GM8 and the round element airbox, provided it is in my budget.
see sale threadIf its OK, I would like to get first on the list for the GM8 and the round element airbox, provided it is in my budget.![]()
I don't have enough to swap out the 4l80 for an allison. So the 80 will get red clutches and shift kit. And detune the vans tune. It will still run better then the 6.5 did.. so no you didn't miss anything main reason for getting the van variants
No worries, I wasn't going to suggest allison.
I'm curious to see how the 4l80e holds up behind a duramax in a heavy towing application like yours is going to be.
holds up fine behind a 200hp detroit... i think it will hold up fine behind a 200 hp dmax... esspecailly when i put red clutches and billet converter then bump it up to 300
Who's converter are you going with?
geeze, you get more done in a week than I get done in months! good luck with the swap!
