Will L.
Dude- that was a great engine. It took the small block chevy (most successful engine ever) to knock it out.
On the bodiesOn the engine or the body?
Get it by the quart then mix what pigment it will take to make it the color You want.My sample arrived today. It's a little darker than I hoped, but it may work. Certainly had enough gray in it. Here it is under white LED lighting.
I think the second picture is outside in the natural daylightThat second pic looks like ford blue but the first pic looks exactly like your sample. I like it.
I've been eyeballing that AMC color, too, but at times I think there is a bit too much green tint. If I wasn't picky, then it wouldn't be a big deal.Get it by the quart then mix what pigment it will take to make it the color You want.
This is probably the same color everyone else been showing.
This one listed for an AMC.
Eastwood Ceramic Engine Paint AMC Metallic Blue Quart
Hi-temp. paint with ceramic nanotechnology protects up to 650 degrees Fwww.eastwood.com
