- Staff
- #41
Passlock has ALWAYS been 3 sequences. The only time 1 sequence does it is of it's a 07.5+, and you install a NEW ECM, then it will take the code on the 1st attempt. Otherwise they're all 3 key sequences(except for early passkey system's, but that's a completely different can of worms). And I highly doubt your cluster is causing the issue. It's only connection to the TDM is a bulb.
